\r\n \r\n I went -1 in the front and +2 on the rear i also installed a FI cage to help protect the bike some. so were should my rpms be when trying to clutch it up i got the front wheel up mabey a foot then lost it and now its like it dont wanna come up\r\n
Threads: 19
\r\n \r\n once you have it up, stay on it, learn the feeling before you worry about balance point and catching the bike with your rear brake. pucker your butt and go for it.\r\n
Threads: 9
\r\n \r\n \r\n \r\n \r\n Originally Posted by DclarkJr\r\n  \r\n \r\n I went -1 in the front and +2 on the rear i also installed a FI cage to help protect the bike some. so were should my rpms be when trying to clutch it up i got the front wheel up mabey a foot then lost it and now its like it dont wanna come up \r\n \r\n | \r\n
It\'s not about Rpms it\'s about how much throttle turn you need. Baby steps start with maybe 1/4-1/2 turn on the throttle and dump the clutch.. See how high it comes up. then work up\r\n
\r\n \r\n Ok i will give that a try if it ever stops raining\r\n
\r\n \r\n ok i got my bike to wheelie mabey a foot off the ground but cant get any higher i dont think i am clutching it up right! i need some advice on the clutch or somthing please help!!\r\n
Threads: 6
\r\n \r\n \r\n \r\n \r\n Originally Posted by T-Dubby\r\n  \r\n \r\n It\'s not about Rpms it\'s about how much throttle turn you need. Baby steps start with maybe 1/4-1/2 turn on the throttle and dump the clutch.. See how high it comes up. then work up \r\n \r\n | \r\n
thats the best advise i think i have ever heard. i wish i had been given that nugget when i first started riding.\r\n
Threads: 3
\r\n \r\n \r\n \r\n \r\n Originally Posted by DclarkJr\r\n  \r\n \r\n ok i got my bike to wheelie mabey a foot off the ground but cant get any higher i dont think i am clutching it up right! i need some advice on the clutch or somthing please help!! \r\n \r\n | \r\n
your not giving it enough throttle, or your chain is loose. thats all i could think of, it\'s late.\r\n
\r\n \r\n \r\n \r\n \r\n Originally Posted by Spooner806\r\n  \r\n \r\n Can\'t be scared. Eventually you\'ll fall down. I do it.......alot. \r\n \r\n | \r\n
Hey... Me too!!!\r\n
\r\n \r\n i just had a tune up on my bike but i will check the chain and see if its loose.so should i pull the clutch all the way in then rev then let go of the clutch and should i be in the power zone around 6 0r 7 grand or should i be less with the rpms\r\n
Threads: 14
\r\n \r\n \r\n \r\n \r\n Originally Posted by DclarkJr\r\n  \r\n \r\n i just had a tune up on my bike but i will check the chain and see if its loose.so should i pull the clutch all the way in then rev then let go of the clutch and should i be in the power zone around 6 0r 7 grand or should i be less with the rpms \r\n \r\n | \r\n
no you don\'t have to pull it all the way in. just enough to slip and and bring the rpms up and walla. its just a matter of finding that right walla. just keep on practicing. one foot today will be 2 foot tomarrow if you say with it and so on.\r\n
