Threads: 23
A lot of times when you are going slow they coil up like that almost instantly. Think about whats happening when it breaks, the front sprocket is pulling the chain forward but nothing is pulling it out the bottom.
It's actually less likely to coil up when you're going fast, they tend to shoot out clean then.
You do know the round part in the picture above the chain that the motor mount is going through is a spacer and not part of the engine right?
Ya I know, thts not what im tlkin about. The bolt going into the case on to the right of where shifter linkage hooks up. And ya I guess it makes sense. Im sure it can still spit out the chain when ur going slow though, my luck just suks
Threads: 23
Ok so your talking about the bottom motor mount. I have a bunch of shit to do today but if you want to bring the bike by another day I can take a look at it.
Ya exactly, and ok thanks ya im working all week so bikes guna sit till the weekend anyway. Im proly guna go ahead and order chain n sprocket setup now I just gota do some research on here to find out who to buy it from and what kind etc. Il post pics later when I get home
Threads: 39
Dude you can 5 minute jb weld all that drama and be popping wheelies
Threads: 12
B954Fl
Ya Im pretty annoyed with the whole ordeal, Im not sure I just bought the bike not even a month ago i think its a 525 though it snapped at the masterlink. Idk what u mean by staked but If u mean wire rapped around it to keep clip on then ya it was staked. You would think the chain would snap and just fly out ya know, not get all coiled up like that. Right when i felt chain snap i turned the bike off its not like i kept it in gear. And i was at a dead stop to begin with when i was cutching it up, I wasn't going fast.
by staked i meant was a rivet link that requires tool to install.
Threads: 8
Sucks man, and maybe pics don't do it justice but man that doesn't look all too bad. OMR or someone else locally should be able to fix that up no problem if you wanted to weld it up and not just do the JB weld route. Doesn't look like you need a new engine or anything though.
loogie
If it was you would you drop the motor and jb it or leave it in,take the bolt out put jb around bolt and crack and thread it in with jb all over it? And I know I cann jbweld it the problem is will it hold. Ive jbwelded a crack in motor mount before and ya it held for 2 weeks and I thought everything was all good and it started leaking again.
lee majors
Ok got it thanks
