BRO-18
Holy shit, that diagram is crazy lol
StrictlyStunt
You'll have less problems running aftermarket upper stay. Especially running a stock headlight, keeps everything up there solid.
What is Upper Stay... sorry for the dum questions
BmoreNate
greedy start of the thread, holy shit.
but what Bro said ... also, if your wire harness is all jacked up different ways check the wires where they go into the plug assembly itself, mine got kinked and worn so I had 1 copper cable out of the 7 or 9 or whatever in the line actually making contact. bumps on the street would make my light go on or off. at one point I also put my head lights on a toggle switch so I could run at night, ftp :lol
tru ill see, if nothing works ill do that thanks bro
Threads: 17
A stunt stay does the same as your stock upper stay. The piece in front of your bike that holds your gauges and headlight together in order to mount to the bike. Only difference is the stunt stay is made out of steel and won't brake on you from continuously coming down hard with all that weight in the front, where as the stock upper stay is made of weak aluminum.
This is a stunt stay I rock on my bike when I put the front end on. It's from staystealth. The windscreen is not a regular windscreen but part of the stunt stay and also made of metal. It's all one piece.
PHOZE
Nice, and thank you, im learning new things all the time!
Did you find/fix your problem?
BRO-18
nope, mad cold outside..lol now snowing man this sucksss....
Found the Problem, it is the starter button , cuz when the light shut off, i just touch that starter button and it turns back on again
