what's the best handbrake setup lol
#11
Quote Originally Posted by OnEWhEeLNEAL
any bracket that accepts radial calipers will work with the r6 calipers if you want. I don't know how much pads are but they're probably more expensive than the 600rr/1000rr calipers i been rocking. $30 a pair for pads
+1 but you will have to mod either the caliper or the bracket since the spacing is different for the pads to sit with the rotor....for ex: on the 05 636 obviously you can use the stock rotors and calipers, but if you swap a set of r6 monoblocks on you need 310mm rotors (+10mm more) i would assume the same here so that can either make for a bigger big rotor kit or shaving down on caliper/bracket...
Quote Originally Posted by kevin09
the fti kit comes w spacers for different calipers but yeah you right
oh for real?! i didnt know that i thought it was just already pre made for certain calipers like all the other brackets out there, thats good info to know
would the fti bracket accommodate the 310mm rotor and r6 monoblock with no trimming, or extra spacers other than the ones provided?
FTI RADIAL (always see these confused with a dual quad) bracket is made for a busa rotor, not too sure on the size for that (definitely not 310mm though, something like 220-240mm?). The spacers are decently sized, so I'm pretty sure a caliper with more spacing (r6 monoblock) would just require a smaller spacer.
I like motodoc's setup, but you have to mod your own rotor to make it fit, and I don't own a motodoc bracket so I don't have any experience on it. FTI is just bolt on, but Bill@FTI is kind of busy nowadays so I'm not too sure on availability.
FTI all the way. Bill just got his machines back up and running and we have a big shipment of the brackets coming in next week hopefully.
Quote Originally Posted by Moto-Madness.com
Do i hear a celebration sale or group sale comin?
Haha see what I have after all the back orders are filled but since he's back up and runing 100% hopefully we usually get shipments every other week or so of them.
well thats a start...sounds good...just put my new front end on last night so i'm hurtin for dough, but if a group sale hits i'll be down like 4 flat tires on a cadillac
whats FTI making, please let me know as im about to buy a new HB setup and dont want make the wrong choice.
