03-25-2012, 10:35 PM
ok so i just need zx14 front rotors to put this front end on...who's got em?
zx14 front rotors/r6 calipers
03-26-2012, 08:04 PM
bump...still need these rotors
03-27-2012, 05:21 AM
the R6 calipers are spaced correctly when using ZX14 rotors? what kawi forks are you using?
03-27-2012, 05:46 AM
08 forks and yea r6 monoblock calipers will bolt right on.....they are made for 310mm, zx14 rotor (310mm) works perfect for em...and they bolt right onto my 03 wheel.
03-27-2012, 02:25 PM
03-27-2012, 02:43 PM
what size are the newer zx10 and zx6r rotors?
03-29-2012, 04:29 AM
not sure what you mean by newer, but the 08 zx6 (the forks i have) are 300mm and 08 zx10 is 310mm, however, it won't bolt straight on to my 03 wheel. That's why i'm goin with the zx14 rotor cuz it's a direct bolt on to my wheel and the r6 monoblock calipers are for 310mm. Hope that answers ur question buddy....not sure if you meant newer, like the yr that i have or newer like 2012
03-29-2012, 11:45 AM
u got it, i have an 04 636 with 05-06 forks and wheels, 06-07 zx10 rotors, and wanted to put the 08 r6 monoblocks on it, so does this mean i need a 10mm spacer to avoid pad overlap??
03-30-2012, 10:16 AM
that i'm not sure of bud...i do know that if you go with 1000rr calipers, you need a 5mm spacer cuz the RR rotors are 320mm, if that helps at all...lol
03-30-2012, 10:17 AM
i still need those zx14 rotors guys...and the r6 monoblock calipers that i was gonna get, fell thru...so i need these as well
« Next Oldest | Next Newest »
