Threads: 67
Originally Posted by Cisco
The bike seems to run good overall and wouldn't even be noticable for street riding. Just the low end idle. I am constantly blipping throttle. Currently running -1 front and 54 rear. I am going to start by replacing the plugs. I can't remember the last time they were swapped out. Did I get the motor that was assembled with a hangover? I don't know....
Turn ur idle up if u feel ur blippin all the tweezy
I am having the same problem a little. Not as bad as loogie says my throttle cables were just faked up when he rode it. But im checking into valve adjustment and throttle body sync. 500$ after gaskets and shit at the stealership. Theres a local hero here for less waiting for him to get some time. Also going to 60t soon I think from 53.
Did you sync the throttle bodies at stock idle or with it turned up?
I'll trade you my f4i, then you will have strong pull like am oxe!!
Change ur plugs mine did the same thing, changed.the plugs and it runs perfect
