R6 Cracked Head!!! Frame Flexing? Motor Swap Questions
#11
I watched my buddy punch a hole on his 03 R6 last summer at the lot. He was running an FI cage that mounted to the same spot. I think he just stopped riding after that not even sure if he fixed it or sold it! frame looked fine but he had oil gushing out of the head!
get the new atc cage......
and get a new frame!!!!!! push that head back even and have a shop reweld it. do not plate it becuase it WILL warp. its to thin of cast and it will f that head up.
Quote Originally Posted by CT Mike
i though of trying to fab up some inpact spring sliders like tygersharks for the atown cage never got around to it .. wonder in that coulda helped
Any other input?
doest need spring loaders with the new cage....the new mounting points are 100% better and actually go into the block instread of the head. DO NOT use that old frame. you will break heads like crazy. those 2 front mounts on that head have to be at a right width or it will keep breaking. salvage the head while you still can becuase these motors and motor parts are expensive to fix
Quote Originally Posted by !!A2K!!
i was thinking of trying to porto-power that ear of the frame back out and fitting it on the new motor til it slides on smooth. Onces thats done, weld it a support brace that would cover and extend the mount down and around the mount? not a good idea? or just start fresh, buy a new one
this should work with smoothing the ear down till the frame slides over the motor smooth but id be kinda careful with welding the frame it might weaken it
Quote Originally Posted by Atown1101
old cage was flawed with the mount point! new one is good
okay sweet, ive got the new design
id just buy a frame lol
yea thats what ill prolly do, just get a salvaged frame and put my numbers on it since this bike is allready has a reg. and i dont wanna spend a crazy ammount of money on another frame and title
just get a "race" frame.....stamp kits are 50 bucks and people sell "blank" frames for dirt cheap.......these motors start at 800 bucks, the head start at 200........200 is a blank frame shipped to your door with out the mess
just and update
well i got around to painting the frame/wheel stuff up and got it back togeather this weekend, took it for a quick ride seems back to normal with new frame and motor. Working on getting the rest of the body painted up, took a quick cellphone pic before i rode. Thanks again for Atown and hookin me up with a new cage,!!
