03/04 zx6 build with 05/06/07/08 parts
#11
\r\n \r\n And the fun begins. I despise working on bikes already Good luck w the build though homie \r\n
\r\n Originally Posted by OnEWhEeLNEAL\r\n View Post\r\n
This...Ive done 2 frame swaps and built like 4 03/04s in the last couple years...I move rit\r\n
yeah it takes lots of time...more for me since this is the first time iv worked on a kawi haha
yeah, and seems like partially building mine with all the help ur giving me
\r\nheres update on what i got done today
\r\n\r\n
\r\n \r\n this is how far iv gotten....just test fitting stuff...have impaktech cage and subcage coming....esd rearsets and pegs for the subcage.....si side mounts 7* and some other parts....
\r\nnow just debating whether to get steel frame now or later and also when i should buy the fti dual cal bracket
\r\nand my stockpile of tires i got today
\r\n\r\n
\r\n Originally Posted by kevin09\r\n View Post\r\n
Nice progress...If you have the coin do the steel frame now, that way you can ride it and not feel like its made of glass and actually be able to chuck it here and there learning new shit.\r\n
\r\n \r\n yeah i really want one but only way ill get it is if i sell my f4i frame and motor and my 05 636 frame, swingarm and tank then ill have the money and space to do it haha by the end of winter it will most likely have a steel frame...\r\n
\r\n \r\n which rear shock did you use??\r\n
ok so decided to start a build thread since i actually have some parts to work with now also need help with some stuff but ill figure it out hopefully
this is what i started out with.
then some cleaning and work...
finally got some parts in and tossed on the harness
07/08 shock, but i have an 05/06 one that i might put on instead...the red on the 05 shock would go with my theme i think
