Threads: 18
\r\n \r\n stoppies on ice are sketchy, i can roll reall short ones, but for every 5 attempts, you get maybe one time where the front actually doesn\'t slide MUCH.....i\'m hoping to break 100mph, but after 70 the studs start "floating" and gets a little sketchy...i\'ll practice on it:-)\r\n
Threads: 6
\r\n \r\n im usually not a big fan of these kinds of record attempts. But this seems like a record worth holding. I dont see alot of people comin after this one. I wouldnt want to wheelie on ice at all, much less at 100mph. Good luck ryan!\r\n
Threads: 27
\r\n \r\n \r\n \r\n \r\n Originally Posted by Ryan_S\r\n  \r\n \r\n stoppies on ice are sketchy, i can roll reall short ones, but for every 5 attempts, you get maybe one time where the front actually doesn\'t slide MUCH.....i\'m hoping to break 100mph, but after 70 the studs start "floating" and gets a little sketchy...i\'ll practice on it:-) \r\n \r\n | \r\n
add about 100lbs of lead weights to the front of your bike and soften your forks all the way. im sure the front tire will grip and the rear tire will come off the ice!!!
\r\ngood luck...im sure you will be able to power wheelie over 100mph thru the gears. sketchy part may be putting it down above 120!!!!\r\n
Threads: 29
\r\n \r\n i called them about me wheeling on water and they laughed at me... but they took you serious??? lame
Threads: 4
\r\n \r\n \r\n \r\n \r\n Originally Posted by Guru\r\n  \r\n \r\n i called them about me wheeling on water and they laughed at me... but they took you serious??? lame \n  \r\n \r\n | \r\n
I was wondering how long it was gonna take
Threads: 12
\r\n \r\n Is there a record for fastest wheelie on ice already? If so, what is it?\r\n
Threads: 36
What are u... Jesus?
Threads: 18
\r\n \r\n \r\n \r\n \r\n Originally Posted by SIC J\r\n  \r\n \r\n Is there a record for fastest wheelie on ice already? If so, what is it? \r\n \r\n | \r\n
\nno
Threads: 16
\r\n \r\n Good luck Ryan
