Threads: 11
\r\n \r\n i have extra 636 calipers. do they mount up fine? is the hole spacing the same as what you have drilled? and does it come with spacers? lmk before u send the rearsets back i might have you throw in a bracket\r\n
\r\n \r\n little pad trimming n a littla caliper shavingdue to the 636 not having a true round hub. mounts fine with 636 caliper, ill get ur spacers nuts and bolts\r\n
Threads: 43
Likes Received: 1 in 1 posts
\r\n \r\n \r\n \r\n \r\n Originally Posted by A.TEK\r\n  \r\n \r\n little pad trimming n a littla caliper shavingdue to the 636 not having a true round hub. mounts fine with 636 caliper, ill get ur spacers nuts and bolts \r\n \r\n | \r\n
What caliper can we use so we dont have to trim it???
\nWTF??? Caliper trimming??
\r\n \r\n u shave the bottom backside of the caliper case because kawi gave the 636 a huge brakeside whhel hub thats not perfectly round so the hub rubs the caliper on the lopsided part. i shaved mine to get the most pad contact. ill post pix tomorrow, u may not have to grind the caliper casing at all. e.dub (pictured) uses n 04 gsxr 1k and only 3 washers but had to trim his pads a little.\r\n
Threads: 43
\r\n \r\n So wait a minute here... may have to trim the caliper casing??? or use washers to space it right??? or trim pads?? or all the above.......\r\n
Threads: 11
\r\n \r\n \r\n \r\n \r\n Originally Posted by A.TEK\r\n  \r\n \r\n u shave the bottom backside of the caliper case because kawi gave the 636 a huge brakeside whhel hub thats not perfectly round so the hub rubs the caliper on the lopsided part. i shaved mine to get the most pad contact. ill post pix tomorrow, u may not have to grind the caliper casing at all. e.dub (pictured) uses n 04 gsxr 1k and only 3 washers but had to trim his pads a little. \r\n \r\n | \r\n
Dude its SUPER easy\r\n
\r\n \r\n correction, edub said he did NOT have to trim pads. this is the tokico 600/750 caliper shave for 03/04 636 wheel. i DID have to use a spacer but do NOT have to trim pads\r\n
\r\n \r\n YES you can use ANY of the 4 piston radial calipers
\r\nYES you can use the LEFT or RIGHT side
\r\nNO they are not the same
\r\nYES they all will require some sort of spacing or everyone would have to be custom made
\r\nNO you dont have to modify every caliper
\r\nNO you shouldnt have to trim any pads (but may have to modify caliper for this)
\r\nYES this IS what you want
\r\nYES 2 6 x 6 stickers will be included
\r\n$125 gets it to the door
\r\n2 nylon threaded nuts and matching universally usable bolts will be included\r\n
Threads: 11
\r\n \r\n Bump how are the rear sets coming\r\n
\r\n \r\n got the profile measured and the width. sorry its taking me a bit longer, the fingers getten choppes off set me back.\r\n
