Threads: 12
Originally Posted by da Liks
i want it.
I'll trade it for some 700+ endos
Originally Posted by klos
I like the blue rims
Soon to be gone. Those ebay plastics are trash
Threads: 12
Originally Posted by A.TEK
just get a new tank, ebay tanks like that and 05+ 636 are cheap. denting tanks is always fun. if its hard to fit your tank back on after you dented it then ur dents the wrong angle/too deep. you can flip it over, bang it back and hit again. since its still on the bike. get a section of pipe you can fit in the gas cap opening, stick in, and go back-forth-side to manipulate the cap a little back to normal
I'll check that out once i drain the tank.
Threads: 12
Since no one is posting up any other tips I'm just going to post up all the mods im doing to set it up.
Here’s the tip over sensor.
Just pry it apart and glue the sensor in place. I didn’t know if it would mess up the sensor if I got glue in between 1 and 2 so I just glued all around it.
I just used some clear silicone I had laying around.
Threads: 12
also Picked up some stock fairings this weekend for 50 bucks. There a little beat up... nothing the new paint won't fix.
life platics, great job on the silicone, u can fill that thing up with it and be ok. or hot glue, no superglue or anything though.
thats a nice 636, should pick up a bracket for that too while ur at it. the guys coming tomorrow with his 06 for me to measure so i'll be able to have more design time with it
Threads: 16
ok but you pay for shipping!
Threads: 12
I thought about it.. then I realized I have an endo bike.
Its like any trick. If you can't do it... its the bike! Right?
Threads: 12
It was the vent tubes. Fing GSXR'S.
Threads: 16
so true! what kind of bike do you have as an endo bike?
Threads: 3
Here�s the tip over sensor.
Just pry it apart and glue the sensor in place. I didn�t know if it would mess up the sensor if I got glue in between 1 and 2 so I just glued all around it.
thanks tl! you're the man! i had to lay the bike over on its side to work on the height adjustment links and forgot about this stupid sensor! so now it won't start, it will tomorrow! i understand why they make this, but they should sell a part to bypass this crap!
