Tire Pressure? spinning tire?
#11
\r\n \r\n pilot roads last a long time but i didnt feel like mine had any grip at all , i lowsided a couple times just getting on the gas a little too hard in a circle ..\r\n
\r\n \r\n Why not the tried and true pilot power or do you like the less steeper tires? I almost got a pilot road 2 awhile back because they didn\'t have any powers and i needed to have a tire for FFC\r\n
\r\n Originally Posted by T-Dubby\r\n View Post\r\n
Why not tried and true pilot power or you you like the less steeper tires? I almost got a pilot road 2 while back cause they didn\'t have any powers and i need to have a tire for FFC
did you type this from your evo dubbster? \r\n
\r\n \r\n wow thanks for all the input. I def did get a few more clutchups without spiinign tires last nite, but dont think its all about my clutch control since i didnt have spinning tire probs before this tire. I do LOVE the tire for burnouts and even got a couple baby drifts, slides realllll nice! sometimes too much, i low side-ed alot lol
\nIve heard bad things about the bt023 like they are too sticky?\r\n
\r\n \r\n a little tip i give alot of people when i see them spinning on clutch up is to not pull the clutch in as far before the clutch up , just pull the clutch in far enough so it is still dragging a little then clutch it up ..
\nseen this work wonders\r\n
\r\nseen this work wonders
you said "tip" \r\n
\r\n Originally Posted by IV\r\n View Post\r\n
No that was just my shitty writing that I do if I do fast and don\'t proof read it haha\r\n
Brytni, this is the same thing i have been having issues with and i think OMR hit it right on. This is the same thing Cory tells me to do when my tire spins, it\'s so but i have just working on trying to be smoother on the clutch and do what OMR just wrote.\r\n
\r\n \r\n Try Pirelli Diablo STRADA... it\'s Perfect.. for everything!
\nBut roger is right!!!\r\n
\r\n \r\n its not a tire "problem" just some grip less than others etc etc..Try not to snap the clutch out as much and give a bit more slip..all that torque hitting it is causing it to break loose. Try to get smoother with the clutch release and transfer weight to the rear tire as much as you can. learning to ride/clutch whatever on different tires is just another sometimes annoying learning curve.
\nand also if its a BRAND new tire give it a few sessions and it will burn off whatever they coat the tires with to keep them from sticking the mold..that shit is slickk\r\n
