05-21-2010, 04:12 PM
I'm working on a promo vid right now should be up in an hour or so
$85.00 Secondary (Dual) Caliper Bracket 03/04 636
05-21-2010, 04:13 PM
Soon available for 05/06 and 07/08 swingarms???
05-21-2010, 04:15 PM
To answer the first question I ride the 07-08 zx6r now and yes it fits the same
05-21-2010, 04:17 PM
Yes you still need to use the stock adjuster bracket only becouse they are seprate but they still work off of the axle so it's the same adjustments
05-21-2010, 04:25 PM
05-21-2010, 04:26 PM
Thanks man spread the word.
05-21-2010, 04:39 PM
Sorry for all the questions.. but one more just popped into my head
What is the thickness of that bracket??? 1/4", 1/8"? That is why I was curious about still using the stock adjuster.. I personally would rather have it made of thicker material and eliminate the stock adjuster just for piece of mind and durability...
05-21-2010, 06:24 PM
FTP, yeahwith slimmer steel u worry about bending under force, i use a cold-rolled aluminum block, it still affords for a much higher tensil strength then hot-rolled. the design here, if you use a gauge to measure spacing then you would no longer need the axle block, it just would keep the nut from moving because there will be a gap from the nut to the lock pin not to thread jack, but if you take a look at mine, not sure if you can see but the adjustment lines are already marked and scribed, if you have a simple hole in your bracket and use the oem piece over it then ur not getting a precise adjustment but not enough to make a difference
05-21-2010, 06:50 PM
Yes it can be made thicker it is made of 1/4 in now but can easily be made thicker to replace the adjustment block.
05-23-2010, 01:53 PM
Works like a champ!
« Next Oldest | Next Newest »
