03-18-2010, 07:54 PM
636 ?
636 ?
03-18-2010, 09:04 PM
what kinda breather should i get.. to let air flow but not oil??
03-18-2010, 09:14 PM
I got a valve cover breather from autozone
03-18-2010, 10:46 PM
Is oild coming out, I never had a problem with the motor.
03-19-2010, 11:58 AM
personally i would look or buy 2 new factory covers and replace the block off plates so you can hookup the T fitting, unless your not riding in the lot with the bike or if its just gonna be a streetbike then i wouldnt bother with it.
03-19-2010, 12:09 PM
do yall have any pics of the the t fitting way i have mean like the post pic my bogs low idle when you go to cluch it
03-19-2010, 02:24 PM
make sure you capped off the vacumm line that comes off the stock T valve. some guys remove the stock T valve and hook it up that way and others remove the stock T and put in a plastic or brass plumbing style of T fitting, thats what i did but not sure if it will make a difference
03-20-2010, 12:46 AM
03-20-2010, 03:41 PM
the way i did it i left the stock t fit on the head cover and ran a holes from the back to front left stock there the two 1/2 pipe and the 1/8 plug in cap the air box off is that ok or do i need do something else
03-20-2010, 05:20 PM
« Next Oldest | Next Newest »
