Kleen Air Mod
Kleen Air Mod
#11
\r\n Originally Posted by jc_hernandez_wtsn\r\n View Post\r\n
so i need to buy hose #4 about 2.5 feet? and a t fitting if the valve doesnt stay open?
\ni got 1/2 inch and got like just under 2 ft.\r\n
\r\n \r\n just got around to doing mine today... took me 10 min. max
\nused all existing parts except for hose #4 and the caps.\r\n
\r\n \r\n this is specifically for the 03? so the 04 and up wont hydro lock?\r\n
\r\n \r\n What about the gases that are created? The hose to airbox is ment to ventilate these gases out, does they go out from exhaust with the mod?\r\n
\r\n Originally Posted by P-ham\r\n View Post\r\n
04+ will still need this mod.
\r\n Originally Posted by mart211\r\n View Post\r\n
Yes, that\'s why some bikes puff some smoke after high BP tricks, it\'s the oil being burnt up in the exhaust.\r\n
\r\n \r\n very usefull info ...\r\n
\r\n \r\n if you dump your bike with the tip sensor disabled... yes you will hydrolock as you airbox fills with oil.
\nso do the wheelie version kleen air mod for the stunt bikes.....
\nDO NOT DO THE RACING SMOG PLATE WAY!
\nso the photo above is fine, just run the tee and a long hose to the crank case... or honda back to the valve cover left hand side usually.
\nalso don\'t forget to cap the 2 hoses you remove on your airbox and superglue or hose clamp.\r\n
\r\n \r\n Do u have to do the clean air mod on a 05-06 636\r\n
\r\n \r\n yes. all bikes you plan on riding wheelies, you must do a clean air mod.
\nit takes 20 minutes or less to complete. and cost less than $5 usually.\r\n
\r\n \r\n Do everything in that stupid picture except for #3 (connecting the side thingys together)\r\n
