Threads: 9
WHEELIE
That's wrong.....
you twist the Adjuster screw on the lever all the way in & then Turn the adjuster out on the cable to take out
the slack, and then unscrew the adjuster on the lever out to finish it of...
Hope this Helps you better than Righteous's Lame way of doing it...
there aupposed to be any freeplay on the lever?
Str8JDM
yeah, Fam from stunt farm told me there's supposed to be a nickel size worth of freeplay. the nickel being vertical, not horizontal
Quality products, great customer service, super fast shipping, all my orders got to me in 2-3 days and that's across the country. Wish all stunt companies were run like this.
Threads: 28
Hi Righteous
Righteous 1
Screw the adjuster on the lever all the way in. Adjust out as much slack as possible at the bottom adjuster down at the engine. Make final adjustment at lever. Should do the trick!
Meant to copy wheelies instead of Josh's but Josh's is accurate, turn adjuster in all the way on lever then back out like 2 turns, adjust cable down at engine so it's pulling tight no slack at lever, then adjust lever back in those 2 turns and should give you plenty to adjust the slack for desired. Doing it your way will leave no slack to turn the adjuster out unless you leave some at first at the lever
Threads: 28
Stubbz63
Mine is described exactly as Josh's.. Just worded different
Threads: 22
emailed rsc, ordered exhaust, trying to order subcage,,,, check emails lol
Threads: 67
ajbsays
What are u setting up now? How's that 13? Post da pics of some action shots
Threads: 22
Duane S.
the 03-04 and the 13 is sooooo nasty, smooth, killer!
