02-19-2011, 10:47 PM
This is the F4i, there are many F4i's and perhaps 2 others this caliber of a bike. The price is $4gs, as is, as you may have seen it this year as I have traveled all over the us. The bike has a clean Florida Title, in hand. Please keep in mind before you start hating that the front end alone on this bike is worth more and the majority of the bikes on here.
The bike runs perfect, I'm going to ride it tomorrow. All the wiring is modded via heat shrink connections. All the stock connections are still present and there if you wanted to run street or full fairing. All the Powder/Parts were assembled Jan-Feb 2010
-Suspension
954 front end
954 vented wheel - not the solid 929 that crack, straight
Mirror Polished 954 tubes
Ohlins Cartridges - These were $1,599 new and discontinued
Type FG R/T
Length 720 mm
Stroke 120 mm
Fitted Spring 4745-95
Hohey top tree
Hohey damper mount
Ohlins Damper, blue label, its bran new
All Balls Bearings
Stock 06 shock
Seal Savers - I have never blown a set of seals
- Frame
Plated by Bob Runman - Built Bill D's bike
-Brakes
Galfer Lines, 3" longer than stock up front,rear,hand break
Hohey Street fighter Bracket
2010 CBR1000RR Chrome Rotor
Front Calipers powder inca candy cold. I have the rear, needs seals
Stock front master
Hohey Rear Sets
Sick Fat Pegs
Sick Heel gaurd's
Folding levers both sides
Only OEM Honda pads used on rotors
-Engine
2006 Engine, salvage auction bike, I bought and cut it
new plugs,oil this month
Fresh Sync
This bike has the "Magic Wheel" anti bog
06 radiator, straight, dual fans with welded mounts
DCP Rad Support
Ceramic coated header
Ceramic 2bros carbon fiber shorty, just rebuilt
Honda Oil,Filter,Lucas Oil Stabilizer used
StuntX Oil Pick Up
Has full gage set up
- Gearing
Vortex 60t
Vortex 14t
RX Gold 525
06 hub,cush's
- Controls
1000rr kills witch
1000rr throttle housing
06 f4i cables
Vortex 7" clips
RSC Ultimate
Brembo 16 R1 Master Handbreak
stock f4i front master
Only Motul rbf600 used
Renthal Carbon Kevlar Grips. If you don't know you better ask haha
- Stunt Parts
Sick Cage, Alumn Pucks
Sick SubCage
Sick Round Bar
Sick Seat stander plate
HSP Gauge Mount
DCP Custom Riser TubeS
DCP Foot Plate
Custom 2 inch tank lip
billet gas cap, no tank leaks ever
dankine tank pad
Sub frame reinforced with rod
- Star Custom Seats
Are not worth a shit
- Pic
Big rotor is gone
Forks are not polished see avatar
-Suspension
954 front end
Type FG R/T
Length 720 mm
Stroke 120 mm
Hohey top tree
Hohey damper mount
All Balls Bearings
Stock 06 shock
- Frame
-Brakes
Stock front master
Hohey Rear Sets
Sick Fat Pegs
Sick Heel gaurd's
-Engine
Fresh Sync
DCP Rad Support
StuntX Oil Pick Up
- Gearing
Vortex 60t
Vortex 14t
RX Gold 525
06 hub,cush's
- Controls
1000rr kills witch
06 f4i cables
Vortex 7" clips
RSC Ultimate
- Stunt Parts
Sick SubCage
Sick Round Bar
HSP Gauge Mount
DCP Foot Plate
dankine tank pad
- Star Custom Seats
- Pic
Big rotor is gone
