I have been trying to learn stoppie on my Honda CBR 600RR. I can come to a stop and do a stoppie, but not really ride it out. I don't have any problem with the rear tire, it comes up fairly easy, but the front one always slides out. Just wondering is there anything I need to do with tire pressure? BTW I am running around 35psi. How much pressure do you put in the front and rear tires for doing stoppie?
Thanks..
Threads: 43
Likes Received: 1 in 1 posts
What kind of tire?
The proper tire will help alot..
Also what are your suspension settings set up like? Hard? Soft? Compression? Rebound? Preload?
Outlaw_FTP
What kind of tire?
I don't know much about suspension settings. Everything is factory installed.
35 is a good psi you dont want a low tire psi because trying to do 180 or control it is alot harder...when yo go into your endo pinch your knees lift u ass up to help pull bike up but only 1/4 of an inch or so and square of you shoulders and always look foward...t- neck tought me years ago behind a whare in o town been killn them ever since...get a pilot power 2ct best grip tire
Threads: 16
zinomori
Thanks..
what kind of tire!!! how old!!! how cold is it where you're at! how clean is the surface you wanna roll on!!
answer those first..
Threads: 43
da Liks
Any advice this guy gives.. take it!!! He knows his stuff...
Heal up buddy!
Threads: 16
Threads: 58
Likes Received: 4 in 3 posts
Likes Given: 17
32psi, pilot power will grip to a wet turd in 30 degree weather.
Threads: 67
