I grew up using CR high bend on all my dirtbikes and quad so naturally I put them on my stunter because it felt right. I feel like I could man handle the bike more with db's then clipons and it made jump throughs easier with the extra height. My
I grew up riding dirt bikes and still ride alot....and i agree it makes alot of stuff easier but imo if you want to make everything easier you might as well stunt a supermoto... and leave the big bikes to the hardcore sportbike riders..
Threads: 57
jcf4i
pro taper cr-mids will give you the most room for mounting your controls. Youll be able to push you hb master all the way in and get a HUGE increase in hb power. When shopping for db bars its tuff, because the specs dont tell you where the bend starts and stops. Go to your local race shop and look at a set of CR mids and a set of reeds. Close in specs but there is a huge difference in the bends. Reeds would give you more room for your legs in HC, but IMO CR mids , or another bar with equal mountable 7/8 area is best. trust me
blee
+100000000000000
I'm runnin pro taper contour "atv low" which are identical to "CR mids",I was lookin for the cr mids but they didn't have any in the color i wanted in stock and my boy at the shop said that the atv low's are exactly the same as the cr mids,I love em
WRONG!!!!!!!!!!!!
The ProTaper Suzuki/KTM bend has the most room. This bend has the least amount of pullback which allows you to move your handbrake in the furthest. ProTapers only have 3 dimensions, overall length, height and pullback. The pullback is what will determine how you are able to mount your shit.
Likes Received: 7 in 5 posts
Likes Given: 8
i had a couple different sets on my bike and the carmichael bend rotated forward worked and felt the best for me.... if i ever went back thats what i would run
richd3000
now i have that 97 gsxr6 complete front end on my bike and the forks measure 30in and i have the tubes flush with the top upper. if i tried to raise the tubes an inch or inch n half and just run the clips on top of tripple would it mess up my rake angle? i dunno what stock is cus i never had it. i already have the clips and would save me 80 bones if i went that way, but i dunno about the frontend height. f4i gurus help me please!!!
Pro Taper Contour Henry/Reed's for sale
still minty fresh from when I put on clip ons
my boy runs these on his 01 F4i and <3's them
Threads: 57
nj636
wheres your hand brake?
YSRRider
what's a hand brake? don't the pro's use them ?
Pullback is a measurement of how much the bars PULLBACK toward the rider when mounted straight up, Ysr shut the fuck up. no advice from turds please.
I had the fat gold charmichale kicked way forward for a while..I dont really like dirtbars but that set up was pretty sick...bars are super wide too..you can adjust alot with them.
