Threads: 31
We are now selling a new product on our website that Superior Performance is making... The 85 dollar Secondary caliper bracket (Includes Shipping) "It is not a dual caliper bracket because it is actually seperate from the stock one, and still utilizes the stock foot brake bracket".
We have one on one of our team members (Chad Flowers) newest bike, and it looks great... He rode it last night and it locks the tire up with much ease... it is very light and strong... Very simple design hence the low price... We are excited to offer it to the public through our website!
Please visit here to purchase
http://adrenalineboyz.com/?cat=13
New Style Secondary Caliper bracket Made by Superior Perfomance:
This is a Secondary caliper bracket that utilizes the radial block style caliper. This is an all steel construction bracket, and is powdercoated for rigidity and looks. This bracket is a must have for stunt riders, and makes changing the rear tires quick and easy! The threaded studs are mounted to the bracket as an extra insurance to insure that the caliper stays connected in the event where a bolt/nut may come loose.
Threads: 43
Likes Received: 1 in 1 posts
In the first pic... this still utilizes the stock adjusting block???
How about one for the 07-08 swingarm.. which I believe is the same as the 05-06
Also what caliper does this require? right side honda like all the others? or something different?
Threads: 12
Awesome! If I didn't have a hohey already I would pick one up
Threads: 26
Likes Received: 3 in 2 posts
Looks to be a GSXR Front Tokico
Threads: 31
I believe a GSX like Frays said or a kawi front will work... good question... we just grabbed whatever we had laying around... Either side will work too, just have to flip the left side one to bleed because the nipple would be on bottom. i will get the measurements of the space in-between the studs and post it up so you can see if your caliper will work...
Threads: 12
From what Ive read pretty much all radial calipers have the same mounting points so you could pick up almost any radial caliper. I'll let someone else confirm that but I remember reading that in something Bill from FTI posted.
Threads: 31
[QUOTE=Outlaw_FTP;696111]In the first pic... this still utilizes the stock adjusting block???QUOTE]
Yes still uses stock adjusting block... I personally thought this was a sweet feature because it takes the guessing out of the wheel alignment adjument... Just adjust as normal, and then throw this thing under it...
Threads: 43
Originally Posted by ADBZ Matt
Is it required though?? I use a feeler guage when adjusting mine just to know they are spot on and equal.
Threads: 31
I do the same with mine... I guess i dont fully understand your question, but the bracket is snug to the center axle keeping it the exact same distance from the rotor at all times... when you adjust your wheel using your stock spacers the bracket moves where you put your spacers...
Hope this answers your question??
The spacing center hole to center hole is 4 1/4 in
