01 f4i no spark
01 f4i no spark
changed the key switch, not that
checked all fuses, not that
what else can i look for?????
Do you have injector pulse? Some hondas use one power wire to run a few things and coils and injectors are one of them. Oh! It also runs the fuel pump. Is it priming?
Originally Posted by NME
yup primes good
pulse generator! its behind your right side engine case.
Originally Posted by tonyf4i
+1...also pull apart EVERY plug/harness and check for moisture/bent prongs/loose connections then go from there
ok be back in a few
ok dont know if this will help but i just pluged in the gauge there is the neutral light and a red light, under that the oil light is blinking. any ideas???? and how do i check the codes???
ok, i have no spark...very minimal voltage to my hot side of the coil and no ground on the ground side, however i have .4 ohms of resistance from the coil ground to ECU ground...stator checks good continuity and good output...i think anyone know what the spec is for stator output on this thing?? also from what i said does this bring any sugg
