Threads: 19
frayz
I don't know why people just don't buy clutch side masters. LOL
No reason to change what works. I've had the same brembo since I started stunting.
Threads: 19
Righteous 1
Here is the PM just sent out to all that had paid for and got shipped a lever. My foot injury kept me from being able to mount up and test a final run perch.... :-( ...Also....I was too excited to get these out there. My one off prototype perch that I tested had a lever angle VERY similiar to and MSR, and was much more comfortable and adjustable. Somewhere along the programing transition between my prototype and the final product, my machinist changed the angle. He has promised me a new set of perches by Tuesday to send out to replace the incorrect ones. I feel like shit about this whole thing.
Respect to Kyle......he informed me of something being screwy. So this morning I had my wife help me mount up a final run perch and lever in place of my prototype.....sure enough....lever angle was way off. Thanks for bringing it to my attention, Kyle.
At the moment, the lever angle is going to be the only thing changed on the perch. Thanks for your other suggestions though, Kyle.
PM I sent out......
I really appologize guys......I didn't get to test the finished product before I sent out the orders due to my crushed foot. Incidentally, the perches sent out with your order are not machined in accordance with my prototype, and the angle of the lever is inward as such that the lever is too close to the bar, with no room for adjustment or personalization. I talked to the machinist this morning, and he promised me new perches with the correct angle, very similiar to an MSR on Tuesday. So....once again, I appologize. Do not try to mount your unit until you get this new perch in the mail, unless you want to be dissappointed.... :-( .....I wish my foot hadn't gotten so fucked up, and I woulda tested the final thing before I shipped.
If you can send back the perch you have, we can machine it to the correct specifications for a future order and not loose out on those pieces of work. I will paypal you $15 upon receiving your perch. I hope you all understand.
Sorry.....and thanks for your patience. -Josh
AWESOME! good to know that it wasnt meant to be like that hahahaa
i will send back the perch today and wait to see what i think till i get it back..
is there any way i could get a longer lever made?
..like a inch longer
and some more material machined off the perch?
then it would be purrrrfect
Thanks Kyle your set up looks the same as mine and i was wondering if the clutch lever was gonna be able to pull around my hand brake.. I will also wait for new version then purchase
krazykyle85
I know I am not too good with clutch/handbrake...
But I like my way.. It's my only way to go.. Lol
just like guru kills it with hb on top!
But the msr works with all those styles..
The righteous stunt clutch should be modified so it can do the same!
.. That's my
Agreed, and I really cant say much cause you obviously murder Clutch/HB with your current setup... but just from my many years of experience, everyone who i convinced to try mounting the HB as far in on the clipon as possible has loved it and said it helped them with a lot of tricks and control.
I think ur right thou about it needing to fit everyone's setup and was glad to see that you and Righteous could work together on this, in the end it will only help everyone!
awesome reveiw kyle!!
righteous ur the man!
Threads: 14
krazykyle85
Nice!
Longer levers are still about a month out.
If you end up thinking you'll want to keep it after you get the RIGHT perch,
........pull out the grinder and do work, bro. I made it thick for ultimate strength, and there is plenty of material that can be removed for cutomization. That was my thinking.
Threads: 14
Razors_Diesel
Thanks, bro.
Just trying to do business the right way.
frayz
on the brembo you can just swap the banjo and bleeder and you have a clutch side master for about 100 less.......lol
What I find the most interesting in this thread is Kyles clutch side grip!
Props to Righteous for taking criticism and working to fix the problems that have arisen. Set up looks good and I look forward to putting one on my bike when the time comes.
Threads: 19
Righteous 1
Nice!
like i just sent you... on pm...
what makes you think we want to put a grinder to our 80 dollar clutch perch.
the whole clamp area should be machined down when the perch is fixed or a longer lever should be offered.
because like i have shown. it is not able to be used like a msr in its current form.
the lever doesnt even reach my grip.
with my msr i have the whole flat finger are covering the grip....
thats kinda a big diffrence
what do you think about this?
should i just send the whole think back and stick with msr?
i cant wait a month for a lever to use this perch...
