Make over on my 50...From poo to AWESOMENESS!
#31
\r\n \r\n \r\n \r\n \r\n
\r\n Originally Posted by Razors_Diesel\r\n View Post\r\n
heres the set up i was lookin at..........
\n
\nrim setup
\nhttp://cgi.ebay.com/ebaymotors/BLUE-...=p4506.c0.m245
\n
\n
\nrear caliper
\n
\nhttp://cgi.ebay.com/ebaymotors/REAR-...=p4506.c0.m245
\n
\nradial master (id have to flip the cup over to make it the left side)
\n
\nhttp://cgi.ebay.com/ebaymotors/16x18...=p4506.c0.m245
\n
\nWhat size line did u use?
The rear caliper link does not work . You need to post the full link .
\n
\nThat rim has no brake panel . you will need the right type hub panel on the right side for it to work .
\n
\nA regular stock crf50 brake panel fits into the hub on a stock wheel , but it also slides in the notch on the swingarm .
\n
\nAnd the caliper will need to be mounted to a bracket . And the bracket will have to work on a stock crf50 swingarm .
\n
\nMost chinese knockoffs with rear discs , also have different swingarms . That is what that rim assembly is designed for .
\n
\nAnd i\'m guessing that fluid resivoir on the lever would fall off or crack when you drop the bike and the bars hit the ground .\r\n
\r\n \r\n Nice bike playa.\r\n
\r\n \r\n kudos\r\n
\r\n \r\n haha sick man!\r\n
\r\n \r\n damn that rear brake setup looks good. Does it work at least 10% better than stock cause that would be awesome.\r\n
\r\n Originally Posted by buddy lenzin\r\n View Post\r\n
I am about 3/4 the way done the rebuild on it... Buddy and I went shopping at 50 stunt and bought some goodies and we are building up our engines now...
\n
\nNew parts are;
\n
\n- Stage 3 88cc Big Bore kit
\n- High volume oil pump
\n- Heavy Duty auto klutch kit
\n- CDI box
\n- Throttle body and cable
\n- Rear tire
\n- UFO plastics (black)
\n- New seat apouhlstry (Heather added the buddy lenzin and stiched the seat for me)
\n- ASV front brake lever
\n- Black hand grips
\n- Green and Black paint.....
\n
\nI stripped it all down ground off all the old paint and dirt and painted the entire frame green (exact green as on my ninja) Hand gaurds are balck, entire engine is going to be black, Exhaust is black but the heat shields are green as is the tip, The shifter and kick start are green, the foot pegs that bolt to the engine are green, Front and rear rims are black, and the sprocket will be green. Im thinking of painting the rear foot pegs green to and I re painted the gas tank gloss black as it had a ton of over spray on it from when I was painting my legos....
\nI dont think Im going to but a ton of stickers on it, maybe one or two of our bc stunters and thats it...
\n
\nI am hoping to have the engine built and be riding it ASAP but we will see how it all goes.
\n
\nSo, here you go. You all know what it used to look like....
\n
\nOld.
\n
\n
\nbefore Sanding the frame.
\n
\n
\n
\n
\nNew paint.
\n
\n
\nNew seat and plastics
\n
\n
\n
\n
\nPainted the rim balck, brake arm green, and the fork tube covers black.
\n
\n
\nPut on the hand gaurd and grip as well and the rear brembo brake. Cant really put on too much more until I get the engine back in.
\n
\n
\nMock up with the seat and plastics.
\n
\n
\nNow I got to build the engine with my friend so I hope we figure that shit out because I want to ride this thing! I am sure I am going to have to relearn everything cuz of the stage 3 88cc big bire kit but thank god for my brembo rear brake!
\n
\nI dont think I am going to be letting randoms take this for a joy ride anymore...at least until I bash the shit out of it a few times..
\n
\n
\nWho did them seats? they are !! pm me please!\r\n
\r\n \r\n My friends girlfriend in Abbotsford BC.
\n
\nShe cut and stiched it, and I wrapped it.\r\n
\r\n \r\n could be sweet!\r\n
\r\n \r\n Are You Going To Put A Bolt In Your Brake Lever .. Or R U Gonna Leave That Ziptie On There ... Not So Safe...\r\n
\r\n \r\n HERES SOME PICS OF ALL THE FIDDYS I BUILT.. I HAVE HAD ABOUT 5 OF THEM ... AND THIS THREAD IS MAKING ME WANT ANOTHER ONE ....
\nMY FIRST ONE
\n
\n
\n
\n
\n
\n
\n
\n
\n
\nBACK IN THE DAY WHEN IT WAS FUN
\n\r\n
