11-26-2007, 11:11 PM
hey im looking for any drifting advice i can i found a hook on free used tires and i want to start burning um
drifting
01-01-2008, 04:33 PM
yeah some tips would be nice, I�m trying and trying but I just don�t get it to the point, can do some 180 spins from time to time but not more.....any pro tips?
01-01-2008, 06:18 PM
I was told by roger to lean and gas it. I'm guessing high rear tyre pressure would be good to make it grip a bit less.
01-01-2008, 07:58 PM
finally some one replied to the post [image no longer available] duff thats kinda the idea i had goin but i think the clutch is still involed some how
01-01-2008, 08:08 PM
Probably to break traction and start it I'd say, kind of like when you start a burnout. [image no longer available] Hopefully I'll have my bike working soon so I'll have a go and report back. [image no longer available]
01-02-2008, 06:13 AM
Quote from: old duffer on January 01, 2008, 10:18:29 PM I was told by roger to lean and gas it. I'm guessing high rear tyre pressure would be good to make it grip a bit less. That�s what I do, come in with a powerbrake slide, get the right lean, rev it up and let the clutch out fast like on wheelie or burnout without any front brake involved but often I just make a wheelie with alot of lean [image no longer available] my tire pressure is not too low but maybe I should go higher.... [image no longer available]
01-02-2008, 11:09 AM
Quote from: TRICKY on January 02, 2008, 10:13:17 AM That�s what I do, come in with a powerbrake slide, get the right lean, rev it up and let the clutch out fast like on wheelie or burnout without any front brake involved but often I just make a wheelie with alot of lean [image no longer available] my tire pressure is not too low but maybe I should go higher.... [image no longer available] try putten a lil pressure on the front brake to try to keep that wheel down
01-03-2008, 06:21 AM
Quote from: skater38053 on January 02, 2008, 03:09:31 PM try putten a lil pressure on the front brake to try to keep that wheel down alright I�m gonna try that when weather gets better over here, thank you
01-03-2008, 10:28 AM
i know what you mean its like 30 here [image no longer available]
01-03-2008, 12:56 PM
lmao, we had a high of 9 degrees today, 30 would be heaven....
