Where are you getting your cage from ?>
sambo
Chris @ fuel forged is building me a cage and sub cage
JBoom
Post some pics of your fab work when u get your HB installed. Looks good so far
Caliper bracket and calipers line up great, should work nicely! The handbrake caliper in this picture in not the right one, but you get the idea!!
Mr Weber
Like a glove!!! Nice work man.
JBoom
Thanks buddy! I hope to have more done by the end of the week
UPDATE!!
Completely removed ABS system! and rear pegs
Relocated the gage cluster! also installed Idle cable and removed stepper motor, but you can not see it in this picture
The way it sits now. Should see the cage, subcage, and seat this week! Next, need to measure and order all brake lines and master cylinders! Tank is a week or 2 out yet
Threads: 22
Likes Received: 1 in 1 posts
Likes Given: 1
take a hammer to the tank already!
Threads: 21
broham
I already did! The tank on it there is the minty one, the dented tank is out at paint! I put this one back on so i could test and make sure eveything was still working correctly after removing all the abs and stepper motor! Here is a pic before it went out to paint, Thanks!
Threads: 22
Likes Given: 1
Mr Weber
looks pretty good. Was it tough to dent? and about how much bondo build up do you have on that lip?
