Impaktech stunt cage installation help
Sup everyone, just need some pointers and help and makin sure I'm install it all right.
Doing it 0n my 05 Cbr .
So this Is what came in.
So my questions are, the long threaded rod goes in the engine bolts by the rear set ?
And do I remove the castle nut on the right side of the bike by the rear set?
& for the mounts where usually the "frame slider goes" the black bolts just screws in and the silver one goes on the other correct..?
And what about the provided washer ? Do i need to use em too? So fAr I have it pre set up and almost looks correct but doesn't fully feel secure ..?
On the right side , I installed it with the castle but still on. Is this correct ?
Any help of advice would help, thanks guys.
And for this screw "18" , I'm assuming I use the provided bolt and then use the lock nut once it goes thru the engine frame .?
some more pics for verification , took off the engine bolt on the left side, then push out the rod out the right side, now does th castle nut stays, or comes off too?
& what about the spacing for this??
does the provide bolt just goes straight thru with the oem engine spacer and bolts up?
pre set up of what it'll look like
bump,
reserved for more phots to come....
