Plan on doing a handbrake too?
Im thinking of stunting mine but the cage gives me mixed feelings. I sorta want that even. on each side.
The progress looks impressive. I like how you changed the rear sets also.
best option is to make it urself.. pikeeso also has a topic here.. he made it himself
stuntride.com/vbstunt/showthr...rr-second-bike
Truly craftsmanship
How did you get the plastics back on after welding it?
Also is your steel subcage welded to the aluminum frame? If not, how did you bond your subcage to the frame?
Dimes
Made holes for the metalwork to go through
i saved the undertail by guiding the metal rods next to them.. which left me only having to make 4 holes in the side fairings.
Dimes
Aluminum frame ? heck no.. all steel baby
hmmmm...
chopped the footpegs by and inch so i could finally check the ground clearance when it's down on the cage.. and jaiks..
if the homemade duosteps where not on it.. the bike would roll over..
Crapp cage
small update
Discussed the cage over with a friend of mine, i think we are going to lengthen it.
Making sure both wheels stay on the ground... as the above picture is crap imo.
did some little things too:
brake pedal was too high, couldn't get it lower so i raised the brakepump with a homemade bracket
And since im gonna ride to the spot ( no trailer etc. ) a rear light comes in handy too
This is sick. Im not "ballsy" enough to take on a wreck. Looks good man!
Thnx, but the bit more technical stuff i call in help from mechanic friends ;-)
Bought magura 13mm + brake line and a nissin second hand yesterday and i gave the frenchies another chance and bought their big rotor kit 300mm with bracket.
Will upload some pictures as soon as i received it all
Not something you see every day. I like it. I like the tile in your garage too lol it was the first thing I noticed
