Tires & pressure?
Tires & pressure?
#31
Quote Originally Posted by !!stretch!!
Pilot road. 28psi or shitty vee rubbers that constantly leak air...start with 30 by the e.d of the day im on the rim
I feel you. I usually start with 30 and end up with 20 by the time I'm loading up. Can't beat free tires tho lol
i ran used track tires for 60$ a pop mounted and i think i ran around 26psi for rear
Quote Originally Posted by StrictlyStunt
Go to a tire shop and buy a little can of the black bead sealant. It's like $15 and will last forever. Whenever I have a used tire that has a small bead leak I mark the tire, pop the bead, and smear some of that for about a 12" section around the leak, reseat the tire and hold it at like 50psi for a while. BOOM, no more leaks
Quote Originally Posted by BU_Stunts1
cool thanks bros im around 32psi, anybody know the pros n cons on the d616, and why some people run there tires backwards?
I'm on my first one now... And I like it... Drifting was easy... They probably flip the tire when one side is worn out cause they can drift to the right...
ya i stick with 28-35psi rear. front is a few psi short of whatever they put in at the dealer.
I run the psi game!
