sicstar.com products thread
I have a bunch of these in stock, ready to go if anyone is interested. They are 1/8" aluminum and come with high quality stainless steel metric bolts and ribbed thread inserts.
$35 - www.sicstar.com/products_id=142
No more gauges zip tied to cages or removed completely leaving you in the dark about all the info the cluster provides, such as idle RPM, Oil LOW, FI codes, TEMPERATURE, Low Fuel, Neutral, etc.
This bracket is made of 6061 aluminum and is Chem Filmed to protect it from the elements and provide an excellent primer for paint or powder if you like. It weighs almost nothing and utilizes the factory rubber grommets for vibration insulation and easy mounting,
The gauge mounts to two of the OEM bolts on the stator cover and will actually tuck under the frame a little bit. It should fit inside of most cages. The stock harness will reach if routed properly.
Get yours now! $39
Post all the products in here, Thomas does not want multiple posts for different items unless its a giveaway or group buy
great idea with the cluster bracket.
Quote Originally Posted by MiNi GuineA
Ok no prob..thanks
Thank you. I plan to make them for other makes/models as well
yea, cluster bracket is sweet!! I might be ordering one very soon
(answered)
Ill take both, need here ASAP tho my white parts are getting powdered end of this week.
Order has been placed.
1001
My discount code isn't working...
I just dropped some chedda bob.
I like new and upcoming companies .
Promote those who promote the sport and new products.
You'll get love in my build thread. And if you want to make some custom parts for the 675 holla at me.
