thermastat 636 replacement
#41
Take the thermostat out, push it open a little with your hands, slide an aspirin in the opening so it can't close all the way.
The coolant will dissolve the aspirin after you fill the system.
Ah... That's what I thought you were meaning, I've never had that much trouble getting air out of the system I guess, but good to know...
Does it overfill the overflow? Will it get up to 240 just idling?
I put fluid inside the overflow......thought your suppose to put some in there and if I sit still with the fans running it'll go to 240 or you talking about dropping the idle down to 1,500 rpm
Quote Originally Posted by navajowalks
damn thats pretty good
When its getting hot does the fluid go into the overflow...? I think is what he's asking
no unless that hose is on wrong which I don't think it is
Quote Originally Posted by Duane S.
Yes you are supposed to have fluid in there but I was asking if it was overflowing. Is it spitting coolant out of the overflow bottle on to the ground?
You were supposed to check that weeks ago LOL
The little hose closest to the cap should go to the bottom of the overflow bottle. Coolant goes back and forth from the overflow bottle and the radiator.
Coolant expands when it gets hot so it needs a place to go, the overflow bottle is that place.
no it doesn;t spit any out
I assume you have checked the coolant level since you last rode the bike?
