Threads: 35
Likes Received: 2 in 2 posts
Nothing but quality!!! Killer job man!
Threads: 12
Threads: 19
Can anyone explain what to do with the lines inside the tank... theres 2 right? So the one line you move to the top of the tank and put a check valve on it but what do you do with the other line? whats that line do?
Graveyard
liked... sick work bro
Threads: 19
*MeatballStunts*
Anyone?
*MeatballStunts*
Anyone?
Pm Mini or Graveyard, they would know...
Threads: 35
*MeatballStunts*
Anyone?
It does nothing, its part of the stock system no longer being used
Threads: 67
MiNi GuineA
so the tank doesn't build up pressure?
Threads: 35
Duane S.
No.. the OEM system vented from the stock gas cap, this modded tank only needs 1 check valve and a extended tube relocated to the top of the tank. When the bike is in a wheelie or on the normal riding position it vents and when the bike is in a stoppie gravity keeps the gas from coming up the vent tube. The second the bike is back to a normal position is will vent again
