So I've been trying more and more to wheelie but can't figure it out.
I know its easy and self explainatory to clutch up but for some reason it doesnt get up that much if at all. Now I am running stock sprockets on my F4 should i switch them out before wasting my time trying to learn.
You guys make it look easy, deff isnt and im use to riding dirt bikes and that is easy. Maybe im still a little scared because the weight difference coming from ridding dirtbikes.
Any Suggestions?
Watch more videos. Read up on technique. Ride with other stunters and ask questions.
I'm kind of in the same boat. I can get it up, but I can't keep it up. Wind up just chasing them out. I was doing that in 1/2, now I'm doing it in 2/3. I know how to get it higher, but with not having a cage I'm just worried about laying it down and breaking shit. Like last time. Solution seems to be simple, just keep adding more and more throttle every time, higher it'll get. That's what I've been doing anyway, but what do I know?
EDIT: I was doing it on stock sprocket before, and it took more gas than I was expecting because I didn't want to yank up on it. Now I've got a bigger sprocket so. Point is, maybe you're just not expecting the amount of throttle it'd take on a stock sprocket? Iono. I'm a big mother fucker too so that had something to do with my situation as well.
Threads: 17
that sounds like a personal problem.
Likes Received: 3 in 1 posts
:lol
ok so sprockets shouldnt make a difference??
yes and no. a larger sprocket will not make a difference if you're not able to achieve bp. I rock stock gearing. I haven't got anything mastered yet but I'm begining to slow them down while on one wheel. in reality cages are made for low speed impact... if in fact the bike were to get away from you or you looped it the cage would probably suffer serious damage and just assist in flipping your bike potentially jeprodizing your tank, ect.
I could balance out stock with only one down in front on my kawi at about 17-20 mph balanced.... def took a handful of gas and a healthy stomp on the rear brake to keep her from flipping on the pick up.... also after full throttle def drop it back down to where you need it to just keep the front end up... try slowly and go for 2 feet then go from there so you don't wreck... also do not look at your rpms... they don't make wheelies, you do... they will still be there when your done with the wheelie...
use the search its amazing what kind of info u will find cuz u are one of a million that asked that probably wont get the best answers cuz most of the people that can help u out answered this a thousand times and dont listen to people that dont know how to do it >> rock star is the best advice i read so for . but u will find lots of threads about this IF U SEARCHED IT TOP RIGHT CORNER!!
I saw that coming, I get it a lot. My buddy keeps telling me he's gonna put a Viagra sticker on my bike and drop a couple in the tank
