F4i won't start
F4i won't start
U put it back in rite that's the way it goes hoses to the front
How the hell are you supposed to get the spark plugs out of this fuggin thing! That bar is dead in the way
It's a pain but possible drop the socket in the hole then ur extention then ur ratchet could it be ur tip sensor somehow it will get fuel and prime and turn over but won't start
Tip over sensor is jumped, just checked it. Gonna dig into it this weekend.
How is it jumped ?just a wire from hole to hole in plug or are the two wires cut and spliced together
Keep diggin... I wanna know what the issue is now... prolly not as much as you but I still wanna know...
haha. Jumped with a wire, gonna splice them and pull the plugs, go from there. Ill keep you posted
Now I'm having the same issue. I've had this problem in the past. I've checked all my relays and tried another fuel pump. Just ordered the base plate to the ignition today. That was the problem last time.
Man, I hope you get it. I don't see how the bike would just all of a sudden not crank.
This happen to me before and it ended up being the ignition diode. It's an anti theft thing. I think I have a hot
Wire. Poping it. We will see when it comes in. You can test it, it's explained on here. I don't have a multimeter. I need one. Lol
