2.5 by 10 tube in a 3.0 tire
will it fit? honda closes in half and need to know if my tube will fit in the street tire i just got 3.0 by 10
99 % sure that it will fit.
^^ don't listen to this douchebag......it's the wrong size......sure it might work but it's not a long term solution.
Originally Posted by Skillz954
will work
the perelli tire is a tubless tire. can i just put it on and use the valve stem off the popped tube to fill it up? like ratchet strap the tire down and try and beed it and fill it up? sounds possible to me
^ No! Wont work, you will just loose all the air through the spokes! Yes the Perelli's are tubeless but the rims are not! Unless you have billet wheels? And yes the 2.50 tube works just fine. Try to get the heavy duty tubes! I always run 2.50 and I have been running on the same ones for over 3 years!
Originally Posted by jack cooke
kool kool ill just put the tube on. looking at the tube on the rim with the tire it looked like it would work just fine. thanks broim on it
make sure you put a rim strip on that rim or at least duct tape around it
2.5 worked out fine, been riding all morning
Originally Posted by my750
like i said...
