03-05-2012, 11:15 AM
F4i wnb stunter -build
03-05-2012, 12:34 PM
im so doing the same thing you did to your tank to mine, howd u cut the bottom out? dremel?
03-05-2012, 01:06 PM
http://hintaseuranta.fi/tuotekuva.as...?kuvaid=533275 That's quite good solution because it's spark-free. Just a note, any of you guys who are working first time with gas tanks: you cannot be careful enough! The less there's gas in the tank, the louder it'll expolode! Do not use any sparkling method for cutting if the tank smells even littlebit of gasoline from inside.
03-06-2012, 06:46 AM
Sub'd. Awesome job so far man
03-17-2012, 01:52 PM
Finally some progress with the crash cage. Still couple tubes short, but the hardest part is done!
03-17-2012, 03:24 PM
03-22-2012, 06:02 AM
Cage looks solid as hell!
03-22-2012, 06:19 AM
Yeah, and it feels like too! Like I said, I'm still learning and hopefully this cage gives me daring to find my limits
![]() I was littlebit suspicious about my 900rr's cage but I think that's not the issue anymore with my F4i - I'm glad that da Liks gave me a hint of this solid cage design I've totally missed before! GOT TO take my DSRL with me next time for some proper pics...
03-22-2012, 02:19 PM
how did you do the front axle sliders? Just drill a small hole through the front wheel end cap?
04-20-2012, 02:55 AM
Hey just curious the grey subframe undertray. how did you do it and what material is it? Welded underneath the subframe? bolted on? I want to do that sometime. Looks so clean.
