What is this box?
What is this box?
i'm about to do that but i just wanna make sure and see if anyone knows
Tokwik...thanx alot man...appreciate it....it's comin off
Quote Originally Posted by ToKwik
CA emmisions are much more stringent than the rest of the country, so vehicles in CA require additional equipment from the factory. This includes motorcycles.
What you are looking at is a purge system designed to catch any unburned fuel vapors before they are released into the air. Long story short, the whole thing can be removed and just follow the regular instructions for the clean air modification. Simply remove the pair valveq and replace with a "T" and run that line to the crankcase breather on top of the rear case.
Hope that helps some.
What he said^^^^
You don't need that shit man. I took mine off. That's the charcoal canister for Cali emissions. Like stated above it collects un burnt fuel vapors.
this is the shit that i took off and the pic of the hose with the screw in it, i think it might be right but not sure. I kept seein people sayin to make sure you block the extra hole on the tank...i know about blockin the airbox holes. well since i had to take that charcoal box off, one of the hoses ran to a filter of some sort just in front of the battery tray then ran up to the gas tank...I left the filter there and everything the way it was and just put a screw in the hose where i disconnected it from the box...anyone know if i did it correct? i ran it til it warmed up and it never threw a code or anything. Also, i'm not familiar with the vaccum line from the throttle bodies that i keep hearin about as well, i never pluged that....PIC please?
if you take it off on the ca model after 500 miles your engine will blow. It is how the government made kawasaki rig them so people wouldnt take them off.
are you kiddin me? i just took all that shit off and threw it away....so what the fuck am i supposed to do about this kleen air then? If there is another RIGHT way to do this, can someone please share. I'm sure i'm not the only one with a CA model that can't figure this out...Pics would be a great help as well.
oh yea, trash day hasn't come yet so i dig it all back out again....funny you say that, cuz when i took it out for a ride around the block, the idle was jumpin around in a lil, nothin crazy, and then when i got on in it in 3rd or maybe 4th, not sure, i made a wierd grinding noise and the rps went up like it should, but the bike didn't move....but it was fine after that...haven't ridden it since cuz the front end is off....does this CA bullshit that i took off have anything to do with this?
*rpms
stuntride.com/vbstunt/showthread.php?t=36698
on this thread they told me that this was the way to do it....check it out for urself and please tell me what you think...thanx
