Threads: 9
Thought Id share the idea, maybe someone is going to find is useful. It's a front 03-04 636 rotor (280mm) w the inside cut out and bolted to a bracket my friend made (Ill post a pic of just the bracket if someone wants me to). Its bolted by 14 bolts w the thread lock and an extra nut on the other side so I don't think its gettin loose. I rode 3 times already tryin to abuse the shit out of it and everything works great. The whole thing cost me $70 (bracket was 40) and it works a LOT better than stock dual cal hohey thing. The rotor was cut on the lathe.
Heres some pics
Rotor came out kinda small, Ill take a better pic tmrw
Threads: 43
Likes Received: 1 in 1 posts
Threads: 45
Threads: 43
I wanna see the bracket that makes the rotor mount up to the hub... and not compromise spacing..
Threads: 9
Threads: 14
Threads: 43
how much you selling that little bracket for? lol..
I have a different hb setup than you but it would be super easy to space it to accommodate a bigger rotor
This is probably a squid question but what's the big advantage of big rotor? My brakes stop just fine ....go easy on me
I just baught the big rotor kit from HHD but this is def. somethin to look into.
