Colder Airbox Mod
Colder Airbox Mod
#51
Quote Originally Posted by Teach
but what kind of 'special' tape is it? especially the gold?
with a lot of shows and burouts comes heat, my bike has gotten to 260-265 a bunch of times. dual fan really not an option but heat wrapping the headers is a poss and maaaaaybe ceramic coating them but prolly not. need to set up a few so cost per bike is an issue
Chris Ive never seen gold tape in the HVAC industry... its probably just a sales gimmik from the company, cause everyone knows gold is better than silver... but i could be wrong, i havent seen everything offered in the industry... I have only been certified for the last 7 years... But I seriously doubt the color is gonna change the effectiveness, unless its thicker or something. But then thicker can hold heat in longer, so more is not always better as I said earlier.
Quote Originally Posted by ROWDY
No Prob man,
EVERYONE Just be sure this HVAC tape your using has some form of insulating properties to keep the heat from transferring into the plastic. This would defeat the purpose completely
Check out http://www.performanceandperfection.com/miraclemod.html to try and get a few more ideas
Is this guy filming in his home garage?
Quote Originally Posted by ADBZ Matt
The Reflect-a Gold heat transfer tape made by DEI is DEF better than your HVAC tape...
Its rated at 850 degrees F and can handle intermittent spikes of 2000 Degrees F.
http://www.designengineering.com/pre...hesive-backing
Like I said... Never seen it in the HVAC industry... Maybe I would have seen it if I worked for NASA tho???
I might order some of this then
[ame="http://www.amazon.com/010394-Reflect-GOLD-Tape-Roll/dp/B0039Z5TUY"]Amazon.com: DEI 010394 Reflect-A-GOLD 1.5" x 15' Tape Roll: Automotive[/ame]
i might try this and see how it works
Im going gold for the extra bling factor lol
OK I finally got to ride the bike last night, and I dont know if it was the DCP Rad cage and secondary fan or this mod... but my bike pulls twice as hard as it ever has! I did not wire my fans to be on all the time, I just wired them together and put a bigger fuse to accomodate the new amperage load, and it kicks on about 212 and is on for about 5-10 seconds and the bike temp drops to 200 instantly...
Try it and let me know if it helps with idle pull cause mine has NEVER pulled this hard!
Quote Originally Posted by Beto
You would probably need about 5-10 rolls of this... it takes a lot more tape than you would think...
Was a great session last night FO SHO!!!!
