0304 636 engine noise
So the engine is quite until it reaches 75 then it starts to make a knocking/ lefter noise at around 3000/6000rpm. The motor was running good until I did a oil change. I put in 10w40 syn. I can't really recall the sound being there before the oil change. Either way does any know if this is oil? Needs a valve job? Or should I go ahead and buy a new engine when this one blows up. I don't really beat on it, just drifts and 1st endos to the limiter. Any suggestion would be helpful before I start spending money. Thnaks.
Oh and noise is coming from up top and it doesn't make noise when you first turn on the bike. Only when it gets to operating temp.
Factory or manuel cam chain tensioner? cct is a common problem for kawi's
