righteous easy pull on drz??????
#31
Quote Originally Posted by Righteous 1
The standard is always my personal fav. Full length lever is also a good idea, if it'll work w/ your HB setup. Yes, I have green in stock, but only a silver spacer....no green spacers, yet. The silver spacer looks good, though.....it ties in w/ the stainless hardware and the adjuster. Hit up the site!
Gonna order now thanks rush it to me lol
my bad i have a 450x....the R parts wont work...i ordered R parts before and it didnt work
i just ordered both the long lever one in green and a silver spacer so make sure that my order ships together cuz ur website wouldnt allow me to order together only seperately so i think im getting charged $8.00 too much lol but no trip if you catch it and send together in same box as an added bonus lol
Quote Originally Posted by onelegstunter
lol i just red my receipt lol sorry .... its cool
Looking for following setups... search not working
Drz400sm
Cage
Hb
Anything else?
Quote Originally Posted by DJFireUSA
Drz400sm
Cage
Hb
Anything else?
nothing available for them man, cage is made one of nothing in production but PM onelegstunter he might be able to send ya pix of his he made. handbrake probly junction valve is only thing available i dont think theres a DCB out there. skip the cage get stiff driver pegs and axle pegs for protection and handgaurds, build your own roundbar and get an RSC you should be good.
Yeah, the hand guards already did their job. Bike now has axle sliders front and rear.
The friggin rear brake needs some serious detuning. Works too damn well. Don't dare use it unless i wqnt to break the rear loose. Accidentally touched brake pedal ever so slightly while buried in a turn and low sided. Obviously not a big deal (low siding) but shouldn't have happened. My fault... bad foot placement on peg so when leaned over, road bumped foot which put pressure on rear brake pedal and rolling on the ground i went. Hmmfff
Sometimes it's the simple things that you over look...
What are the chances that my rear brake sensitivity is related to a worn tire? Common thinking would cause me to think the more worn, the more rubber in the contact patch, more traction.
Thoughts?
Thoughts?
That could be the problem, just try a less worn tire to see if there's a difference?
Used to lock up my front tyre at stoppies when the tyre was worn, fresh tyre and almost no locking up the front wheel
ordering another rsc tonight for the drz. Im ordering without the spacer and Ill see how it works and order the spacer if i need it. I dont think i should need it
