05 R6 Builder Upper
05 R6 Builder Upper
Well i just got a smoking deal on a salvage title R6 dude came through at last second.
Need a few things.
title and frame (this is salvage title and want to hit the streetz)
Aftermarket rear sets
subframe and or options
chain and sprocket
black ht moto pad for tank
vortex gas cap
MOD list to do to these?
no naarden who can i buy from?
Originally Posted by loogie
Phil @ thrust/motoheaven for the drive kit.
A-town for the subframe.
Bortner for the HT moto,vortex cap,rearsets.
kleen air mod,fuel pump mod,TB mod,and do work!
pretty sure the "r6 pictures thread" covers all this.
Lets talk abot mods
Fuel pump looks like it gets some screws put in it.
Originally Posted by ~03~raven
Alright, well I misinformed you. It is only two screws and they are small sheet metal screws. They are on opposite sides of each other. They go through the base and through the extra plastic that comes off the pump to form the tab that holds it in place. These hold the pump in the base very secure.
Here are the pics.
I removed the fuel level sensor so you could see both screws.
BRAVO!!!!
good thing i got these sitting around.
13mm magura
true or false
any pictures?
Originally Posted by KYLE
Just unplugg the tip sensor, use a mini flat head screw driver and pull the connector out of the black portion that hold the tip sensor itself. A little circuit board will come out with a counter-weighted swivel. Just wrap some electrical tape around that counter-weighted swivel so it aligns above the sensor on the circuit board!
what size sprockets you guys running?
http://atowncustoms.com/atc-store/pr...products_id=28
kinda pricey.. id love one tho. Might have to make my own since im cheap.
dent looks sweet and u got mail... tail saver master squid fighter
Originally Posted by sQuiD FigHTer
The bees knees!!!
__________________
i build tail savers for 03-05 R6 and 06 and up R6s if anyone is interested.... stuntride.com/vbstunt/showthread.php?t=17922
Sprocket I wouldn't go more then 9 up it's just not nessecery... Tip over sensor isn't a problem on these bikes and sick or atown cages are the best options... And atown sub is a must along with a steel stay if u wanna keep it FF and I've never had a problem with my fuel pump so I never screwed it but it wouldn't be a bad thing if u did and I would keep the stock cap if u can if not I'll but it
http://cgi.ebay.com/ebaymotors/ws/eB...=STRK:MEWNX:IT
gas cap is the sunk in type which is good.
i went for a spin when i got home and stock i could pull her up no problem.
Ill do a 520 conversion 10 up rear that way it will leave the option to go up more later.
whats stock frt and rear and chain size. gonna go look it up.
frt and rear sprockets are the same pattern for 03-06 r6 so yes an 03 frt sprocket will work on an 06
just remember
03-05 stock gearing 16/48-530p
06 16/45-525p
wtf a 530
you should just sell it to me.......
