post pics of your 50!!!!
#31
\r\n \r\n got something brewing in the office. wrap should be finished in like another week.
\n
\nquestion, is high temp rattle can paint bad on the motor?\r\n
\r\n \r\n \r\n \r\n \r\n
\r\n Originally Posted by B-Dub\r\n View Post\r\n
\r\nquestion, is high temp rattle can paint bad on the motor?
nope, I\'d just be a \'little\' easier about overheating it.
\r\nWhat size is your motor?
\r\nI painted my entire motor, top and bottom end, it\'s a 108cc stroked honda. Now that it\'s summer, I just make sure not to say, hold it at redline for 5 minutes straight, or sit there doing burnouts forever standing still or what not..
\r\nI still rip it hard, and I haven\'t see any problems yet. Stunting and trail riding in 95f heat. I wanna get an oil cooler though just for peace of mind.
\r\nMy friend actually just got an infared pyrometer from work, I wanna run my bike hard as hell for like 20 minutes, then ride to his house WOT the whole way, then check the head/cylinder temp and oil temp... Just haven\'t done it yet\r\n
\r\n \r\n On my engine, I used duplicolor 500f engine paint.
\r\nI also primed my bottom end with regular old duplicolor self etching primer, however its not rated for high heat.. I heard people had no problems running that primer on water cooled motors, so I figure it \'might\' hold up on this one, but air cooled motors DO run a LOT hotter then water cooled (water cooled will typically run at 180 and max around 230 ish) air cooled will run regularly in the 200-250 range and can break 300f easily
\r\nSo far no issues with mine, it\'s holding up great.
\r\nI didn\'t use any primer however on my cylinder or head, as I was worried it would bubble off...\r\n
\r\n \r\n When I redid my bike this year, I had a blown motor already (ran out of oil), so I was already tearing the motor down to replace the crank/cylinder/piston/valves/rockers/cam.. So while it was apart, I decided to paint the entire motor and the bike.
\r\nMy paint job is far from perfect though, I painted all my parts when it was like 30-40f outside... So it has some bad spots, and was hard to stop it from running, even with the lightest coats I could put.
\r\n\r\n
\r\n \r\n I have just a 50cc motor. Got my TTR and crf I\'m thinking about painting\r\n
\r\n \r\n So should I use a primer first? Or does it matter with rattle cans?\r\n
\r\n \r\n Engine paint is thick... Primer isn\'t nessecery\r\n
\r\n \r\n two questions the couple bikes with round bars what did u use to make them.
\n
\nthe bike with the hart and huntington rockstar graphics where did you get them\r\n
\r\n Originally Posted by fiddyrider707\r\n View Post\r\n
\r\nthe bike with the hart and huntington rockstar graphics where did you get them
Solid round bar bent to the shape od the tail and slid into the stock subframe and welded\r\n
bought em from a local shop a couple of years ago. I have not been able to find anyone selling them online.
\n
\n
\n
\nJust finished painting my frame yesterday
\n\r\n
