hand brake set up ?'s - Printable Version +- Stuntride (https://stuntride.org) +-- Forum: Stunt Discussion (https://stuntride.org/forumdisplay.php?fid=4) +--- Forum: Help and How To (https://stuntride.org/forumdisplay.php?fid=12) +--- Thread: hand brake set up ?'s (/showthread.php?tid=8491) |
hand brake set up ?'s - J Free - 11-17-2009 bike is F4i If I am running a Single caliper adapter set up and have the regular single piston rear caliper (not the 4 piston rear caliper setup with bracket), will the stock 04-05 CBR1000RR front brake radial master cylinder flipped work well or is that set up only favored for a dual caliper set up. I can get my hands on one fairly cheap but I cant find anywhere what the piston diameter is on the 04/05 CBR1000RR front brake master cylinder. Thanks hand brake set up ?'s - Moto-Madness.com - 11-17-2009 It will work fine but ideally the Magura 13mm or Brembo 16x18 is butter hand brake set up ?'s - J Free - 11-17-2009 thanks for the input hand brake set up ?'s - N/A - 11-18-2009 I ran the 1000RR master, but I had a dual caliper setup... it worked really well, but make sure you bleed it!!! Don't just power bleed it, I mean do all the little tricks to get every last bubble out! hand brake set up ?'s - lordhunglo - 11-21-2009 just got a DQ setup from FTI... not looking forward to da bleeding...
hand brake set up ?'s - Moto-Madness.com - 11-21-2009 Should get one of these for $45. Makes bleeding easy and i use them all the time http://moto-madness.com/catalog/inde...oducts_id=1030
hand brake set up ?'s - SKETCHY - 11-21-2009 I always fill the reservoir and let gravity do its thing. I always unhook the brakeline at the rear caliper until it starts dripping out, then i bolt the brakeline to the caliper. I loosen the bleeder until it starts coming out of there. Then i bleed the system from the caliper working my way up to the master
