03-04 636 Parts - Printable Version +- Stuntride (https://stuntride.org) +-- Forum: Classifieds (https://stuntride.org/forumdisplay.php?fid=6) +--- Forum: For Sale - Parts/Accessories (https://stuntride.org/forumdisplay.php?fid=15) +--- Thread: 03-04 636 Parts (/showthread.php?tid=53690) |
03-04 636 Parts - onewheelboy - 09-10-2015 03-04 636 parts most small parts will ship for like $10 bigger crap depends on loca Clean frame with clean Indiana title $600 Clean swing arm $30 Clean subframe $75 Subframe with slight tweak in rear $50 Good set of forks $150 Good set of forks $150 Air box $10 Rear fender and chain guard $10 Left clip on bare $10 Right clip on bare $10 Left clip on with switch $25 Right clip on with switch and choke cable $25 Front calipers with master and lever (broke reservoir) $60 Full wire harness with ECU $80 Two throttle tubes one mount $10 Right side rearset w/ shift lever complete $40 Shift lever with foot peg and rod $20 Top triple with ignition and key $40 Lower triple complete $25 Gauge cluster 9892 miles good cond $100 Complete throttle bodies $50 Radiator overflow $free you pay shipping Front rim (has dent could be fixed or used for lot) $50 Rear rim $75 Impaktech 12 bar in good shape about 1/2 of scrape plate left $60 03-04 636 Parts - Runvs - 01-01-2016 Still have round bar 8644389468 pics plz |
