On-Point Performance Adjustable Clip-On handle Bars - Printable Version +- Stuntride (https://stuntride.org) +-- Forum: Stunt Discussion (https://stuntride.org/forumdisplay.php?fid=4) +--- Forum: Stunt Companies (https://stuntride.org/forumdisplay.php?fid=97) +--- Thread: On-Point Performance Adjustable Clip-On handle Bars (/showthread.php?tid=53430) |
On-Point Performance Adjustable Clip-On handle Bars - OnPoint - 02-11-2015 $199 Pre-Order Special. Regularly $349. Introducing the On-Point Performance Fully Adjustable Clip-On. We have been working for a long time on designing the best handle bars imaginable and we are excited to say, it's here! Simply put, this is the last clip on you will ever buy. We are only doing this deal on the first 100 orders and these will sell out fast, so don't delay. Current lead time is 3 months from today. MADE IN USA LIFETIME WARRANTY - CNC Machined 6061 Aircraft quality Aluminum. - Handle bars can be adjusted from a 0 to 4" height - Main Clamps can be adjusted from: forward, to side, to back position. - Available in 0 or 7 degree - Bolt and nut system insure that you will never strip the clamps and allow you to full tighten the clamps so they never slip. - Handle bars are heavy wall aluminum, strong enough to not bend, but lighter then solid rod. - Main clamps are hinged so that they can easily be attached and removed form the bike without removing the triple clamp. Click here to place your order Include Year/Make/Model of bike and 0 or 7 degree ![]() ![]() ![]() ![]() ![]() ![]()
