One more 03 636 steel frame rebuild - Printable Version
+--- Thread: One more 03 636 steel frame rebuild (/showthread.php?tid=52264)
One more 03 636 steel frame rebuild - jep - 01-27-2014
This project got a little head start in summer when I had to get new forks after some kangaroo action. So that's done and only everything else remaining... This is what has happened so far:
At this point I was thinking keeping it white...
then this happened after little reinforcing... sucks when subframe bends a bit after landing on your back
to be continued
One more 03 636 steel frame rebuild - Duane S. - 01-27-2014
like that green homie good luck with the build
One more 03 636 steel frame rebuild - Op4 Stunt - 01-27-2014
who built that frame?
One more 03 636 steel frame rebuild - jep - 01-28-2014
Quote Originally Posted by Op4 Stunt
Stunteam prod.
One more 03 636 steel frame rebuild - Shane124 - 01-28-2014
That frame looks nice
One more 03 636 steel frame rebuild - jep - 01-29-2014
Here is closer view of the frame after drying. Quality sucks but that's what phonecameras are all about
And here is rest of the green stuff
I have also shortened the wheelie bar about 10cm and dropped the suspension to professionals for maintenance and stiffening. And friend of mine is doing a new upper triple with cnc so i have more height play so the front tire doesn't destroy the radiator when I put on my "bolt tires".
One more 03 636 steel frame rebuild - jep - 02-01-2014
Little bit more painting stuff. Black with some green sparkle.
One more 03 636 steel frame rebuild - jep - 02-11-2014
Started putting pieces back together. Next i start building new radiator cage while waiting some parts i ordered.
One more 03 636 steel frame rebuild - Ridick_Bowen - 02-11-2014
Nice studs!!!!
One more 03 636 steel frame rebuild - jep - 02-15-2014
That electric thing (not sure what it is in english) and ignition lock found its place.
Quick check to see what it's going to look like
