Rear Handbrake Setup for R6 help - Printable Version
+--- Thread: Rear Handbrake Setup for R6 help (/showthread.php?tid=5218)
Rear Handbrake Setup for R6 help - SpankDog - 05-13-2009
Ive looked at front brake master cylinders on ebay, fullthrottleinc, gptech etc. Also recently found out I guess I need a diff rear master for my 04 R6 like off a Banshee or whatever would work but the stock one I guess doesn't. .
Have heard lot of opinions etc, I don't really think I need a dual cal handbrake setup especially for how I ride. I don't stunt my R6 in parking lots, I want somthing good but not ridiculously expensive thought about going with fullthrottleinc but id be paying like $300+ for a single kit. I don't mind necassarily if I dont have any regrets later on.
Anyway any input on this greatly appreacited want to get a handbrake ASAP can't wait!
Rear Handbrake Setup for R6 help - DWJmoto - 05-14-2009
you could do something like this https://www.stuntsteel.com/store/stu.../prod_525.html
or you could do a junction valve and use whatever master you wanted https://www.stuntsteel.com/store/stu.../prod_529.html
Rear Handbrake Setup for R6 help - DC-stunts - 05-29-2009
Quote Originally Posted by SpankDog
You need a 1998-2002 R6 rear master and the addapter
I have most of the set up for cheap if you want I run HoHey now. PM me
Rear Handbrake Setup for R6 help - jabreu3 - 05-29-2009
whats price on a full setup for an 03 looking at getting one soon
Rear Handbrake Setup for R6 help - EndlessMoto - 05-29-2009
For a budget setup you can just pickup a used master from nearly any bike; radial masters are even better from the newer R1s, GSXR1000s, 1000RRs, and more. Then you just need the brake line and can have an adapter welded to your stock rear master.
For a setup that should do everything you need and more you can get a Magura or Brembo master cylinder, HoHey Bracket and 80" Line, and a second caliper and you will have a very solid setup.
Rear Handbrake Setup for R6 help - jabreu3 - 06-03-2009
Cool cool I think Imma have to check it out and start pushin' the cash flow in that direction... You can get me some info on that right?
Rear Handbrake Setup for R6 help - EndlessMoto - 06-03-2009
Quote Originally Posted by hooligan3
Yes we can; We are authorized dealers for Full-Throttle, HoHey, Magura, and Brembo so we can get you whatever setup you want.
Rear Handbrake Setup for R6 help - jabreu3 - 06-04-2009
Ill pm you and see what you think would be the best setup for me... thanks again
