2009 zx6r build - Printable Version +- Stuntride (https://stuntride.org) +-- Forum: Stunt Discussion (https://stuntride.org/forumdisplay.php?fid=4) +--- Forum: Projects and Builds (https://stuntride.org/forumdisplay.php?fid=104) +--- Thread: 2009 zx6r build (/showthread.php?tid=51659) |
2009 zx6r build - stuntboy14 - 11-15-2013 Scooped up a a wrecked 09 with intentions to build a new stunt bike over the winter. I've already done a little work on this bike but I'm new to the site so I figured I would make a build thread 2009 zx6r build - stuntboy14 - 11-15-2013 First things first! I've heard the 09+ Kawi frames are super fragile. After reading countless threads on this site I decided to gusset the frame. I want this b!tch to be strong as I'm probably going to drop it a lot. Luckily I have a buddy that tig welds. I dropped the bike off to him and he braced the frame up. 2009 zx6r build - stuntboy14 - 11-15-2013 I went to autozone and found some flat auto enamel that was close in color to the frame. I'll add some close ups of the frame gussets also ![]()
2009 zx6r build - stuntboy14 - 11-15-2013 Here's a list of parts/mods I will be adding to the bike for now: -gusset/braced frame -impaktech cage & subcage -sic star solid subframe w/ round bar -dcp rad cage -sick adj clip ons -driven block off/clean air mod Hand brake and tank dent will be done later. Feel free to add any input. This is my first bike build so any info will be appreciated! 2009 zx6r build - stuntboy14 - 11-15-2013 I used 1/4" 6061 aluminum to gusset the motor mounts on frame. My buddy welded two 1/4" pieces around the factory gusset and boxed it in with some rebar. He also did the subframe tabs with one piece of 1/4". Just thought I would throw this in there since I forgot to add it at the beginning. 2009 zx6r build - DeNoZZo - 11-16-2013 Looking good man reminds me of my 09 build 2009 zx6r build - stuntboy14 - 11-16-2013 Thanks man. Your thread gave me a lot of pointers. There will much more to come. Can't wait to ride this next spring. I hate winter 2009 zx6r build - stuntboy14 - 11-25-2013 Installed the subframe today.
2009 zx6r build - Glennhood - 11-30-2013 So luck to come Across your excellent post. Your post brings me a great deal of fun.. Good Luck with the site. |
