clutch slipping AGAIN? - Printable Version
+--- Thread: clutch slipping AGAIN? (/showthread.php?tid=50558)
clutch slipping AGAIN? - hazemf4i - 08-14-2013
i just recently replaced my oem clutch on an 01 f4i with an ebc clutch kit.. NOTE: when i torqued the springs down i dont think i torqued it to specific torque
its works fine when im riding normal but when i start to practice a few wheelies and the bike gets hot around 220 and stays around that range then the clutch starts slipping from around 6k-10k
anyone have any idea what it could be? when i try to wheelie the bike barely comes up?
last sunday i was practicing and after awhile it started slipping so i left it overnight ..today i went to ride the bike to see if the problem was still there but it left until i started practicing again
note>>>*i just started practicing wheelies.. sometimes im dumping the clutch and other times im slipping the clutch so im still just barely riding it out when i get it up*
clutch slipping AGAIN? - Cuong-nutz - 08-15-2013
Are you sure the clutch cable is adjusted correctly?
clutch slipping AGAIN? - lee majors - 08-15-2013
did you soak the fibers in oil before assembly.
clutch slipping AGAIN? - hazemf4i - 08-15-2013
Quote Originally Posted by Cuong-nutz
Ill try again
Quote Originally Posted by lee majors
Yes
Other possibilities:
1. Springs are not torqued as your noted.
2. You're missing a friction disk or steel disk.
3. You're using the wrong type of motorcycle oil.
clutch slipping AGAIN? - ~03~raven - 08-15-2013
I doubt it has anything to do with the oil. I'd be more inclined to thinking either 1. or 2. if it isn't something as simple as just the cable needing to be adjusted either on the top or the bottom. 3rd option for me would be it's something to do with the stack height if all the discs are there. I have seen it a couple of times that the brand new EBC discs sometimes have a low stack height even compared to a used worn clutch and the pressure plate can bottom out on the basket causing it to slip. In that case we got some slightly thicker steel plates from EBC, 2 of them to be exact, and swapped those out with two of the steels already in use. Damn tight tolerances.
Oh yea man and if you have an RSC or MSR ez-pull, or something else similar, make sure that little adjuster didn't vibrate into the clutch housing and pressing the lever. Seen that happen a couple of times. Just the small little all-thread piece with the nut on it. Here, not sure who's bike this is, but this is the adjuster thing I was talking about. I got in the habit or removing those.
clutch slipping AGAIN? - lee majors - 08-16-2013
i didn't see that it was ebc plates. ditch em for oem and you'll be straight
clutch slipping AGAIN? - Clutchup - 08-17-2013
If I had to guess, its because the springs aren't torqued right. And I always herd go oem
clutch slipping AGAIN? - Cuong-nutz - 08-17-2013
OEM or Barnett
clutch slipping AGAIN? - hazemf4i - 08-18-2013
1)ill give that a try I bought a torque wrench with an analog reading so I know when I stop
2)I'm sure it didn't I think it was 8 friction plates 7 steel plates
3) I'm using the oem honda 10w40oil
[QUOTE=~03~raven;1520148]I doubt it has anything to do with the oil. I'd be more inclined to thinking either 1. or 2. if it isn't something as simple as just the cable needing to be adjusted either on the top or the bottom. 3rd option for me would be it's something to do with the stack height if all the discs are there. I have seen it a couple of times that the brand new EBC discs sometimes have a low stack height even compared to a used worn clutch and the pressure plate can bottom out on the basket causing it to slip. In that case we got some slightly thicker steel plates from EBC, 2 of them to be exact, and swapped those out with two of the steels already in use. Damn tight tolerances.
I just installed a rsc today and I love it man I haven't had ur problem lately ill have to wait until tomorrow when I really practice clutching it up
Couldn't find oem so I went with these I heard oem was the way to go as well
Quote Originally Posted by Clutchup
If it comes back I'm gonna try it
OEM or Barnett
Ebc clutch kit
So today I went to ride and practiced a few clutch ups and I wasn't having a problem at all but I'm sure when the bike gets really hot and after a lot of practice it will probably start slipping again ... Also I noticed a small scratching sound when it's in neutral or low idle until I start to press the clutch the sound goes away i did a little research and I read something about a spacer ring that goes with the first friction plate and there was a second ring don't exactly know if I installed them right I believe I did . I should download the service manual . Can anyone tell me If that could be a problem or what their exact purpose is?
