Foot brake problem - Printable Version
+--- Thread: Foot brake problem (/showthread.php?tid=50507)
Foot brake problem - broham - 08-11-2013
yesterday I was seriously struggling with everything footbrake. I quickly realized that when i hit my fb, it would drag a little until i blipped the throttle. I have a stock fb master and calliper. (03 636). I don't know how to diagnose brake problems. Is my caliper causing this?
note: I don't have a spring on my fb lever
Foot brake problem - GAMstunts - 08-13-2013
Probably need to move this to the help and how to section to get more responses. I would start by cleaning the caliper. I don't run the spring either.
Foot brake problem - Duane S. - 08-13-2013
Quote Originally Posted by GAMstunts
look at the pin that holds the pads too....... take a piece of sandpaper and clean that off........ clean the caliper
Foot brake problem - standupnfall - 08-13-2013
+1 I like to put the pin in a drill with 1000 grit sandpaper if dirty, then followup with a rag and some polish.
Foot brake problem - ~03~raven - 08-13-2013
^^^ This! Pad could be hanging up on the guide if the piston isn't sticking.
I've even used chain/cable lube on the pin to lube it. LOL I've used chain lube on a lot of stuff. Works great on the Clutch arm and the throttle body pullies too. LOL
Foot brake problem - tipper13 - 08-13-2013
that... and also make sure that ur pedal isnt the part thats sticking. the peg could be on a little too tight and causing it to bind up some, or might be real dirty/ rusty between the peg and pedal
Quote Originally Posted by tipper13
yeah this would do it too
Foot brake problem - broham - 08-13-2013
Thanks guys, ill clean the pin, but how do i clean a caliper??
Also, the lever is definitely not grtting stuck
Should have put it in help section, my bad.
toothbrush it some with brake cleaner
